Buderus gb142
Hello,
Hoping to get some guidance on domestic hot water control on my Buderus gb142 unit.
When ever it calls for heat the boiler will fire up and run for less than a minute and shut off on over temperature. It continues to repeat that until the water in the holding tank reaches the target temp. This sometimes causes the pressure to increase to above 30 psi and the pressure relief will release.
Yeah, it’s not working right. Call a competent service company to come out and fix it.
No codes?0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 122 Geothermal
