Need Contractor Recommendations for New Steam Boiler Replacement for home in suburban Chicago
SteveK
SteveK Member Posts: 1
I recently purchased the Schmidt home (Hinckley & Schmidt Water Co.) in downtown Geneva, IL. This home has a two pipe steam heating system...the home is about 4,800 sq ft in size. The existing steam boiler continues to work OK however it's from 1930. As I'm doing a complete rehab of the home, I believe now is the time to replace the boiler. I'm looking for an experienced steam boiler contractor that will do a quality job at a fair price. Thank you.
    EBEBRATT-Ed Member Posts: 19,599
    Sounds like a real nice project. Check "find a contractor" on this site. I think there are a few in your area
    Steamhead Member Posts: 18,209
    My first call would be to @The Steam Whisperer (Formerly Boilerpro) .
    Consulting
  • Dave in QCA
    Dave in QCA Member Posts: 1,806
    Steamhead beat me to it. You are quite fortunate to be in The Steam Whisperer's territory. One of the best in the nation.
    Dave in Quad Cities, America
    http://grandviewdavenport.com
  • Neild5
    Neild5 Member Posts: 203
    You will not be disappointed in The Steam Whisper's work. His tech was here last week fixing a leaking 92 year old radiator valve. They do excellent work!
  • Intplm.
    Intplm. Member Posts: 2,831
    @SteveK
    Would sure enjoy seeing some pictures of your current
    system.
    Please post some here.
    Later, please post the new system.
