Fuel smell discharge from the draft control
hosviolin
hosviolin Member Posts: 1
Every once in a while partially burned fuel oil odor comes out of the draft regulator when the furnace starts. (Weil McClain boiler, Beckett burner, Field Controls "R-C" calibrated draft control, all c. 1990) One time I witnessed a puff of smoke coming out of the draft regulator when the furnace started. The odor is not unlike driving behind a diesel powered truck that is most likely in need of a tune up.
My furnace tech seems not to be able to pinpoint the problem. Is it possible that more outside air needs to be available for the burner? I imagine more than just diesel odor is getting into the air in my basement.
Any ideas would be helpful.
    EBEBRATT-Ed Member Posts: 20,482
    The risk is Carbon Monoxide poisoning.
    You IMMEDIATLY need a new technician and a chimney sweep to check the flue.
    Failure to take care of this could be deadly. Get a co detector down there.
    It could be a blocked chimney,
    dirty boiler
    mis adjusted burner
    or any number of things
    This is what we read about in the news, Don't become a statistic.
    I would shut the boiler down
    STEVEusaPA
  • SuperTech
    SuperTech Member Posts: 2,669
    I would check the cut off on the oil pump. If it's not holding pressure properly after shut down you will get oil dribbling out of the nozzle causing soot, CO and smoke on start up. I prefer oil pumps with a solenoid valve. Is your team have using a digital combustion analyzer to tune your burner? I hope so. It should be pretty easy to check using an analyzer and pump testing manifold.
    DZoroSTEVEusaPA
  • STEVEusaPA
    Agree w/ @EBEBRATT-Ed & @SuperTech.
    Some pre & post purge may help too.
