2+1 Hydrolink, using end ports for 3rd zone?
Using a 2+1 Hydrolink with Alpha2 pumps for zoning, boiler on its own pump through the primary end ports to the left. I've got it flipped over and flanged for the first 2 zone pumps for baseboard and air handler, check valves installed in pumps.
I'm going to be running the 3rd zone as low temp from the "+1" end taps on the right to a mixer then pump then manifold, I can treat those end taps as a 3rd circuit in this case right?
(those straps are redundant, its secured tight with lags through the mounting holes)
  • STEVEusaPA
    STEVEusaPA Posts: 6,505
    Yes, but refer to the instructions about maximum flow rates.
    matt_65
    hot_rod Posts: 28,213
    yes you can use the end ports. I have also mounted them vertically.
    I would add a good air separator also, the small air vent included need some help.
