Geothermal Grundfos circulation pump making noise
oilbox23
Member Posts: 31
Recently bought a new house with geothermal heat. Twice now over the past month or so the circulation pump(Grundfos 15-10B5) has squealed like crazy. Usually turning the heat down and back up causes it to stop but for the most part its quiet all the time. What else is odd is it seemed to do it at the same time both times it happened..roughly 830-900AM in the morning.
I grabbed a video of it this morning: https://flic.kr/p/SKDpsN
It this something I can service or should I have it serviced and or replaced?
So there is a possibility that my geothermal system is heating the water in my house via that pump?0
Usually that pump works when the HP is in cooling mode, taking some of that exchanged heat energy and using it to make some DHW. Maybe your system has a DHW function?Bob "hot rod" Rohr
Living the hydronic dream0 -
geo thermal is a lie, you don't have a geo-thermal system, that's a marketing term for a ground source/water source heat pump which doesn't sound as cool as Geo-Thermal.
You have an efficient heat pump that uses the Earth as a heat source and heat sink by running water through the ground to get it to 55F and running that through a heat exchanger which effectively puts the heat pump in a 55F day whether heating or cooling year round, unaffected by weather.
and you need a new circulator1
- 87.5K THE MAIN WALL
- 118 Geothermal
- 394 Solar
- 15.9K Strictly Steam
- 50 Industry Classes
