Ignition
bean
Member Posts: 34
in Gas Heating
What is the difference between interupted & intermittent ignition?
According to the HW Safeguard Textbook:
Intermittent ignition---maintained during the entire run period of the burner.
Interrupted ignition---cuts off automatically after flame is proved or after predetermined time.0 -
Interrupted ignition seems to cause more or a pulsating flame.
I have recommended re-wiring many oil burners to solve field problems.
Was on a job once with a contractor on an oil boiler that was burning at 7 gph. As soon as the spark turned off the boiler started bouncing on the floor. Wired for interrupted(constant) and it purred like a kitten. Okay maybe a lion, but it wasn't jumping!0
- 87.8K THE MAIN WALL
- 131 Chimneys & Flues
