Replacing lift fittings - what impact on vacuum pump?
SteveZ
Member Posts: 1
I'm working with a 13 story building with 4 long horizontal gravity return lines at first floor ceiling level. Each line has a lift fitting about mid-way back to the plant. In "The Lost Art" it is recommended to replace the lift fittings with transfer pumps, which makes sense. But I wonder if doing so doesn't divorce the downstream return risers from the vacuum source, losing the associated benefits of air removal and better distribution of steam throughout the system.
The discussion in the lost art is about ways to eliminate lift fittings....not that they don't work but it works the vacuum pump hard and uses a lot of electricity. How you pipe it using lift fittings, accumulator tanks or transfer pumps is a little complicated so you have to refer to TLA. And will differ from job to job depending on the job specific piping.
I believe you connect the condensate pump discharge and the condensate vent fro your new tanks into the existing return line which is pulled into a vacuum by the vac pump1
- 120 Geothermal
- 394 Solar
