Air Bleed Program on Vitodens-200
sunlight33
Member Posts: 378
Will turning on the air bleed program in level 2 alone help getting air out of the primary loop?
I notice in the last few days the boiler temperature could reach 175F even though the electronic limit has been set to 165F, not sure if it's due to air I introduced after I changed the Alpha2 pump or due to extreme cold.
- 120 Geothermal
- 169 Indoor-Air Quality
