Replacing a fill valve without draining the system.
Alan (California Radiant) Forbes Member Posts: 4,753
edited January 2019 in THE MAIN WALL
With newfound courage with my ProPress tool, I'd like to turn off the feed valve to a baseboard system, cut the half inch pipe after a defective fill valve and (very quickly) ProPress a ball valve in to stop the flow. If successful, I could take my time and replace the fill valve. There's a floor drain in the mechanical room in case I'm not successful.
Why? I hate purging air from a baseboard system with no vents.
Has anyone tried this? It might be good fodder for a YouTube video.
  • icy78
    icy78 Member Posts: 406
    I've done that on a half inch domestic cold water line in the ceiling in a doctor's office where the copper had worn through and I cut it with a tubing cutter and jammed a shark bite in there on both sides QUICK! I did it over a 5 gallon bucket with a towel draped over it, a big heavy towel, and did the work under the the towel.
    Seems like you could take your ProPress fitting , Jamb a hose over the other end of the fitting, cut thr pipe, move quickly😀, put the ProPress fitting on the pipe and just let the flow run down to the drain or in a bucket and then put your tool on there and press away . I would think that would work pretty well there.
  • STEVEusaPA
    I'm not that brave Alan, but make sure you have someone make a video :)
    Alan, weren't you the one who floated the idea of using that pipe freezing tool?
    If I were to try it, I'd rather jamb a Jet Swet in there to stop the water, then press on the ball valve.
    hot_rod Member Posts: 27,619
    Drop the pressure first, as long as you do not lose much water you should not have air entering.
  • Intplm.
    Intplm. Member Posts: 3,051
    I hate to admit but I did one with a four inch valve. Scared the s**t out of me. Put on full rain gear . The only thing that I think saved me was the main, down stream, worn out, and leaking gate valve that would only partially close. Still there was a lot of water. Floor drain near by in a commercial boiler room.
    So why not go for it . Try and take all the precautions that you can think of a head of time.
    This was when pro-press was relatively new to us.
    It took me from a non pro-press believer to a believer
    Use cordless tools to prevent getting zapped, or worse.
    EBEBRATT-Ed Member Posts: 20,316
    Close any and all air vents in the system. Drop the pressure as @hot rod_7 mentioned. The system will start going into a vacuum. Hook a hose to your new valve so you can jamb it on their quickly without getting sprayed the water will run through it. Then close the valve and crimp while a helper keeps pressure on it. The uncrimped o ring won't let it leak much
