How to purge heating zones when return valves look reversed?
krelian121
Member Posts: 3
Hi gang, first time looking to purge zones since one of the zones aren't heating up. The issue is that the ball valves from videos I've seen are located after the purge valves. In my case, the ball valves are above the purge spouts. If I closed the ball valve...wouldn't nothing come out the purge
spout?
spout?
The Ball valves above the drains are used to isolate the heating loops while you are purging, you need to purge each zone separately.
you also likely have zone valves on the supply side you will need to manually open as you are purging.
Imagine your a marble being pushed through the pipe, chasing all of the air out
1 -
@jellis thanks! much appreciated.0
- 114 Geothermal
