Rinnai cycles randomly
MrsKC
Member Posts: 2
We have a Rinnai tankless water heater that also is our heating system. Why does it run in the middle of the night when heaters are off, everyone is sleeping and there is no demand? It doesn't run at any set time. Is this normal? The unit is in our guest bedroom closet and is annoying to our guests.
Your heat doesn't run at night?Hydronics inspired homeowner with self-designed high efficiency low temperature baseboard system and professionally installed mod-con boiler with indirect DHW. My system design thread: http://forum.heatinghelp.com/discussion/154385
System Photo: https://us.v-cdn.net/5021738/uploads/FileUpload/79/451e1f19a1e5b345e0951fbe1ff6ca.jpg0 -
I have all heaters off at night.0
Does your model have a pre-heat, to prevent the cold water sandwich on the domestic hot water side? If so it is keeping itself warm for anticipation of you turning on a hot water faucet.
D
