National boiler info
skmillersr
Member Posts: 2
I am replacing a No 1 Series Heat Extractor, oil-fired boiler made by National Radiator Company. It doesn't have BTU input or output ratings, only "sq. ft. water" ratings. Do these convert into BTU/hr?
None of that matters. You need to do a proper heat loss (if it’s hot water) or an edr survey (if it’s steam).0
Thanks0
Many if not all of those Heat Extractors had asbestos insulation. You'll need a proper asbestos contractor to deal with this.
Water is 150 btu/square foot, steam is 240btu/square foot0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
