Wrightsoft issue please help!
GW
Member Posts: 5,184
I do a print preview and nothing shows up. I print and nothing shows up.
Apparently I 'unchecked' all the boxes, and the program won't let me print the floor plan i drew; I cant' 'check' the boxes that i 'unchecked". I've done several hundred heat loads and this is the first time i am getting jammed on this one.
I have the 2012 Vesrion maybe that's why???? They are coming to get me???? hahah
thanks
thanks
Can you copy your drawing, close and re-open your program and then paste what you copied back into the program?0
hmmmm i can try, i don't think the program is that smart0
yippeee it worked. I had to go back and forth twice becasue i had two floors Thaks for the tid bit In the pic, don't 'uncheck' the "BUILDING", it will go bye bye
Great!0
yes I never thought of that bc when I right click you get a menu. not the typical cut copy paste windows thing. I went to the tool bar and copied. Thanks again0
- 87.5K THE MAIN WALL
- 118 Geothermal
- 394 Solar
- 15.9K Strictly Steam
- 50 Industry Classes
