Old body Honeywell V8043 zone valve
pyme66
Member Posts: 4
I am posting a couple of photos of a Honeywell zone valve that appears to have an odd (old) round body. The can says that the valve is a V8043F5036 (3/4", 24V) but all the specs I have found online for such a valve have a body with a square flange. The valve has been malfunctioning and I want to upgrade the actuator, if possible, without changing the body.
Anybody recognizes the body of this valve? I called Honeywell tech support and they suggested to install a 40003918-006/U adapter that will allow installing a new actuator. However, the adapter needs a square flange on the body, which the body does not have.
Any help will be greatly appreciated.
Thanks,
Achilles
Thanks,
Achilles
I gotta tell you, in 30+ years, I dont think I've ever seen that valve body.
Nows the time for a zone valves upgrade and ECM circulator.0 -
I'd wonder about the condition of the ball or flapper inside, time to replace them.
Go with a higher Cv valve 7.5 and an Alpha ECM or other brand. You will get a more efficient valve and circulator pump, saving $$.Bob "hot rod" Rohr
Living the hydronic dream0 -
That part shows up on supplyhouse, showing the round body. Looks like you can order motor only or actuator complete0
Does not appear to that old. 2004 maybe.0
- 87.5K THE MAIN WALL
- 118 Geothermal
- 394 Solar
- 15.9K Strictly Steam
- 50 Industry Classes
