Buderus 2107 - 3 zones, separate schedules
aaron_heater
Member Posts: 1
I recently purchased a home that has a Buderus oil heater, & R2107 control box. Heat type is hot water baseboard. We physically have 3 different zones with 3 separate programmable thermostats. I want to be able to run my heating based on the programs in the thermostats.
It's currently in Automatic mode, and heat's based on the program I setup which is close to the Zone 2 schedule, but it heats the whole house based on that schedule. Just switching to manual mode, means that it will heat the house to either the programmed 'Day' or 'Night' temp.
How do I explain to my heater to follow the schedule of each individual thermostat?
Zone info. Zone 1: bedrooms, Zone 2: main home, Zone 3: Basement / entertainment area.
The way I have the thermostats programmed:
Zone 1: Wake - 70 (my wife likes it toasting in the morning)
Leave - 62 (Empty all day, why heat them)
Return - 67 (about 2 hours before bed time to warm up)
Sleep - 65 (about 2 hours after bed time)
Zone 2: Wake - 67
Leave - 64
Return - 68
Sleep - 64
Zone 3: All times: 58, heat only on demand when we plan on
using the area
Zone 2: Wake - 67
Leave - 64
Return - 68
Sleep - 64
using the area
- 120 Geothermal
- 394 Solar
