Lennox pulse question
cgreiner
Member Posts: 1
I have a Lennox Pulse that's run pretty good over the years, but it recently stopped running. it would start to fire for 1 or 2 seconds, then the light would flash once on the ignition control module. Wait 15-20 seconds, and repeat.
I though the line from the pressure switch to the PVC pipe might be clogged, so I disconnected it from the PVC (leaving it attached to the pressure switch). Interestingly, I had my thumb over the end of the tubing, and it fired up, and stayed running. The second I took my thumb off the hole, it shut down. it's currently the only way to start and keep the unit running.
It seems to be the opposite of what I'd expect. I'm effectively clogging the line, and it's the only way it will work. Thoughts??
Lined plenums and return drops, mufflers for the flue and intake, flex gas, flex conduit.
Ah the memories.Steve Minnich0
- 87.5K THE MAIN WALL
- 118 Geothermal
- 394 Solar
- 15.9K Strictly Steam
- 50 Industry Classes
