Outdoor boiler leak
Tom_133
Member Posts: 961
Hey all,
Got a buddy who just found his outdoor boiler leaking in several spots, not pouring out, just small leaks. He has come to terms with a new boiler, but things are tight and he would like to see if he can limp it along this winter. Anyone had success putting boiler stop leak in with a situation like this?
Its a no PSI, atmospheric wood boiler. Sorry I dont know the brand.
Any thoughts? Suggestions?
Tom
Tom
Tom
Montpelier Vt
Montpelier Vt
Fernox F4 might workBob "hot rod" Rohr
Living the hydronic dream0 -
Fire side, or outside leak? Can it be welded? I've welded a boiler on the fireside, not bad if you can get to it and not be all curled up in a ball inside! A stick welder and a grinder are your friend. Be sure to wear proper lung protection.Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0
