Want to insulate walls with heat risers
DrShelley
Member Posts: 1
Hi, My office has heat risers inside the corner walls that provide heat to upper floors so my office is sweltering. Opening windows gets me cold air and a sinus infection. Air conditioning and humidifiers don't help I want to insulate the wall where the riser is with something like an insulated wallpaper that won't catch fire. One wall is about 28 in X 14 feet and the adjoining is about 14in X 14ft.Does such a thing exist? Thank you.
Do you own the building? If so, you could construct a false wall in front of the hot parts and insulate it.Hydronics inspired homeowner with self-designed high efficiency low temperature baseboard system and professionally installed mod-con boiler with indirect DHW. My system design thread: http://forum.heatinghelp.com/discussion/154385
System Photo: https://us.v-cdn.net/5021738/uploads/FileUpload/79/451e1f19a1e5b345e0951fbe1ff6ca.jpg0
