GB142 flue collector
Servicetech1988
Member Posts: 1
I need to replace the rear flue collector on the back of the heat exchanger for a gb142 24/30
I no it had tabs that fold over the heat exchanger. What is the best way to do it so the gasket is tight and won't leak.
Thank you
Thank you
You want to remove the burner .... !0 year or better running / has it been serviced ..Buy a new gasket , pick up a new igniter and sensor and gasket as well ....Easy ... Just pop the clips after you release the motor and gas valve ..
