Laars Endurance F-2 Error Code
rjfischer
Member Posts: 1
in Gas Heating
Hi - I have a 2002 Endurance. I believe it is a EDP Hydronic Boiler. I'm getting LO with an error of F-2. Reset bring the boiler back up and running. It is happening couple times a month. The manual I found calls it an Over Heat Thermostat and my research tells me it is an internal water flow problem causing the over heat thermostat to trip. Does this sound like a correct diagnosis and if so how do I correct this problem? Where is this thermostat located in the boiler? Thx!
- 128 Chimneys & Flues
