Smell pilot when damper Is closed on hw boiler
itzasean
Member Posts: 71
I feel like the fumes aren’t getting pulled into the small hole in the damper when it’s closed for the pilot only. I tried to blow out a match and watch to see if the smoke would get pulled into the flue and it just lingered around the opening . If I do the test at the chimney clean-out it sucks the smoke up the chimney fine . Can I manually open the automatic damper without hurting it to see if it will suck the smoke up while open? My concern is a blockage and the plumber won’t be here for 10 days for the annual maintenance? Thank you
I believe there is a manual open switch on the damper. You could move the switch to open until service tech arrives.0
Do the match/smoke test on your water heater.
It looks like they share the same chimney.0 -
Well I did the test when I opened the door of the chimney clean out and it worked fine . I want to make sure the flue isn’t clogged . You0
Update . So I opened the damper by shutting off the pilot then turning up the thermostat. Then I tried the match test and it pulled in the smoke. I’m surprised the small hole in damper when closed didn’t do the trick but seems fine now .0
If theres definitely good draft with the damper open, then,
after everything is back on line, turn up the thermostat. When the flue damper fully opens and the burners fire, there is manual open switch on the damler motor. Switch it to manual. You'll lose a speck of efficiency but it's fine until the maintenance is done.0
