Heavy doesn't describe it well
Tom_133
Member Posts: 926
Fellow Wallies,
I am currently bidding on a job that has us pulling 2 Cleaver brooks boilers FLX 200-300. I am curious how many have had to move these big behemoths around and how you did it? The job is calling for the removal of one at a time and then replace with the new which makes sense, no heating down time most importantly no loss of hot water.
I need to put a number to removal, so I was hoping to lean on your experience moving these monsters in and out. Sadly they are in a basement, they are about 15' to the door and on a 4" raised pad. I dont know exactly how to describe the exit door but its 10-12' wide and the stairs can be removed. I dont think you could use a crane but a really big fork truck could be an option.
Or can these boilers come apart?
Tom
Tom
Tom
Montpelier Vt
Montpelier Vt
Exactly, YOU DO NOT MOVE THESE, THAT'S WHAT RIGGERS ARE FOR
those units weigh about 6000 lbs, you need a good rigger to survey and price it out, we've had to have walls removed and other wonderful things by a third contractor, the fact that they want to do this in stages is going to jack the price up but it's understandable. This is the statement in their manual--
Fig. 1-1 Lifting the Boiler
Suitable equipment adequate to safely lift and support the weight of the boiler within the restrictions of the chain angles should be on hand when the boiler arrives at the site. Approximate shipping weights for Cleaver-Brooks FLX boilers are listed in the Appendix, Table 1.
If roller dollies are used to transport the boiler, they should be positioned under the base rails at the lifting
lugs. If pipes or other rollers are used to move the boiler, the boiler must be supported by at least three evenly spaced rollers at all times.
******CAUTION! In order to avoid damage to the unit, lifting or moving the boiler should only be done by experienced personnel with suitable equipment for moving heavy industrial
equipment.0 -
I don't think they're lifting. I think it's cutting torch time. I've never did one even close to that big, but even for resi or light comm, I bring in my scrap guy.
We sub it out to a scrapper that cuts them up. It is around $3K to $4K per boiler0
The FLX is a water tube boiler not a fire tube. You can take it/cut it apart fairly easily.
Two ways out.
Rig it out in 1 pc
or cut it up
and take out in pieces. Without seeing it it's hard to tell which way is the best.
Either way what I would do is disconnect gas, oil, water and electrical before the rigger/scrapper gets on the job as they are sure to RUIN something.
Get a price from a rigger to remove in 1 pc (it probably went in that way)
Get a price from a scrapper to cut it up and choose which is best
either way their is scrap value to consider0
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 5.6K Gas Heating
- 105 Geothermal
- 69 Pipe Deterioration
- 954 Plumbing
- 6.3K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
