Replaced boiler return - any special way to fill??
mookie3333
Member Posts: 83
Typical procrastinator - I cut the return back in May, and pushed off repiping it until this past week.. Luckily temperatures held up. Any special way to refill the boiler?? Just wondering about oxygenated water heading directly into the return and causing rust right away. Thanks!
Nope. Just fill slowly in case you have a leak. Once you start steaming you'll take care of the oxygenated water.New England SteamWorks
newenglandsteamworks.com0 -
Your water feeder may engage, as your water will not return until the line is filled. But that will prime the piping with water that has been boiled.0
- 85.9K THE MAIN WALL
- 52 Biomass
- 420 Carbon Monoxide Awareness
- 79 Chimneys & Flues
- 5.3K Gas Heating
- 95 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 887 Plumbing
- 5.9K Radiant Heating
- 378 Solar
- 14.6K Strictly Steam
- 51 Water Quality
- 41 Industry Classes
