PH adjustment and recommended boiler PH.
haventseenenough
Member Posts: 61
What is the best range for boiler PH in a condensing stainless steel or cast iron boilers in a radiant system?
Information should be in the manufacturers installation manuals. It does vary somewhat from type and brand
Hardness, TDS chloride levels are also important to know.
Here is an example and some readingBob "hot rod" Rohr
Living the hydronic dream0
