Disconnect hydronic loops, but keep using bouler's DHW coil
eddo
Member Posts: 12
in Oil Heating
I'm replacing an old boiler with a combi boiler. I'd like to disconnect the hydronic loops so I can attach them to the new boiler, but since it'll take me a few days of part-time effort to complete the work I'd like to leave the DHW connected to the old boiler till the last minute. Is there anything wrong with that? No water in the boiler, just the DHW coil, or if that's not a good idea, any options for me?
make damn sure the expansion tank is still connected to the boiler you're running0
You need water in the boiler, a working pressure relief valve, and the expansion tank connected as @GBart mentioned.
I'd also disconnect the thermostat wiresThere was an error rendering this rich post.
1 -
Thanks. So if I simply cap off the supply and return and keep everything else in place I should be good? Of course I'll make the boiler is filled after cutting those lines and capping them.0
- 125 Chimneys & Flues
- 19 Recall Announcements
