BFD question
hot_rod
hot_rod Member Posts: 28,263
Do you pipe the vent opening to the floor when you install a BFD? Does anyone have a code interpretation either UPC, UMC or ICC that indicated vent piping discharge piping for BFDs specifically?
These ports do periodically spit water if they see a upstream drop in pressure, as they are designed for that purpose, so plan on them dripping or spraying if that condition is ever established. It is not a defective BFD it it spits under that condition. It's doing it's job as intended.
If it is located above equipment, it is possible to have water damage from any discharge.
  • Rich_49
    Rich_49 Member Posts: 2,783
    Here in Jersey Bob , they must be piped to within 6" of the floor and cannot have any threads .
    You didn't get what you didn't pay for and it will never be what you thought it would .
    732-751-1560
    Rich McGrath 732-581-3833
