Mixed-emotions on downsizing
Fizz
Fizz Member Posts: 579
will be leaving/selling current home which has Richardson System fueled by gas and purring like a cat. Haven't had to add or flush waterpast 2 seasons as it's in vacuum and set at 3cph on t-stat. Water is extremely clear. Moving to small cape cod with single parallel pipe set-up, oil fuel.
    EBEBRATT-Ed Member Posts: 20,195
    Life changes. I will be facing that shortly myself. Good luck with the move
    kcopp
  • Fizz
    You are so right. Thanks.
  • PMJ
    PMJ Member Posts: 1,322
    RIchardson gas and 3cph/vacuum to single pipe and oil. Ouch.
    Going to fiddle around with vacuum in that one pipe?
    1926 1000EDR Mouat 2 pipe vapor system,1957 Bryant Boiler 463,000 BTU input, Natural vacuum operation with single solenoid vent, Custom PLC control
  • Fizz
    Well, I don't have expertise to do it, so make best of it. Gas may be in future. The only positive is it's small house, less than 1/2 the radiation.
    look at the bright side, it's not scorched air! you'll make it work!!!
    luketheplumber
  • Fizz
    Posisteamly! Thanks Ed.
