Press vs black pipe
Snowmelt
Snowmelt Member Posts: 1,457
I have the pro press machine, I have 3 boiler jobs coming up, is there any reason I or you wouldn’t use black pipe all the way to the circ pump, including the taco air separator and closely spaced tees? Weil McLain ultra and two cv 9
  • Danny Scully
    Danny Scully Member Posts: 1,465
    Why do you always start multiple threads about the same thing? And no, you can do whatever you’d like. I have precut black nipples that I usually use for my near boiler piping, then press to the existing zone locations. At the same time, though, sometimes I’ll just start with a nipple and fitting/valve, than press from there. It’s up to you.
  • ChrisJ
    ChrisJ Member Posts: 17,069
    I suspect it was a mistake, I only see him doing it this one time?
  • GroundUp
    GroundUp Member Posts: 2,465
    Use whatever you want. Black is cheaper to buy but far more expensive to install, if your time is worth anything. Personally I won't use press in a boiler room because it's ugly and expensive, but then again I'm the dope that sweats everything so it ends up taking much longer and ultimately costing more anyway. Mostly just a personal preference
