category three venting
Snowmelt
Snowmelt Member Posts: 1,457
this I need help on before I attempt to propose the job.
I have 80 condos using takagi water heaters and they have these flush mount kits installed in the closet - outer wall ( there flush with a intake and exhaust category III 4 inch vent. the problem is that it is also used for space heat with a hot coil in the air handler. ( but its still a water heater and its doing a job of heating with no HEX. I want to install this utica cub which is also category III but 3 inch venting so i could just add a reducer into the vent. all the vents are roughly 6 - 8 feet horizontal run with an elbow on top of the machine.
the question is can the existing termination be used here is a picture of it
https://www.energyconscious.com/takagi-concentric-dv-termination-kit-12-to-18-9008000005.html?fee=5&fep=8830&gclid=EAIaIQobChMIlPHT7LCi3QIVwUSGCh3QsAY4EAkYCyABEgK2o_D_BwE
(this is not it but not exactly the same. )
