In-Airid Vent
AnthraciteEnergetics
Member Posts: 77
Picked up an old radiator and noticed this strange looking plug in the top: In-Airid Air Vent, by American Radiator. If I use this radiator, it will be on a condensate zone in the basement.
Anyone know anything about these vents, would it need to be removed if used on HW (non-pressurized - condensate zone from steam boiler located on the same floor)?
1/8 tapping is also there for hot water air bleed valve.
I would take it out and install a small pet cock or ball valve. You will need it to bleed the radiators and then shut it off0
@DanHolohan just posted an article about these vents. They were for single pipe steam systems. As @EBEBRATT-Ed said, you’ll have to remove the bushing completely if you intent to use it for a hot water system. You would then just install the bleeder there. You could also send me the In-Airid bushing .1
Here's the article: https://heatinghelp.com/blog/doctor-bobs-radiator/
And another: https://heatinghelp.com/systems-help-center/in-appreciation-of-steam-radiator-vents/
And the patent: https://heatinghelp.com/assets/documents/360.pdfPresident
HeatingHelp.com0 -
Don't throw it away..It is a museum piecegwgillplumbingandheating.com
Serving Cleveland's eastern suburbs from Cleveland Heights down to Cuyahoga Falls.1
- 85.9K THE MAIN WALL
- 52 Biomass
- 420 Carbon Monoxide Awareness
- 79 Chimneys & Flues
- 5.3K Gas Heating
- 95 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 887 Plumbing
- 5.9K Radiant Heating
- 378 Solar
- 14.6K Strictly Steam
- 51 Water Quality
- 41 Industry Classes
