Replacement options- Lochinvar Nobel VS Navien
andy_16
Member Posts: 12
in Gas Heating
I Have a 1300 sq' ski Home in Vermont that needs the 45+ yr old oil fire boiler changed, Since it's used only use for short stays, I am considering using a Combi unit for replacement to eliminate heating domestic while we are not there and possible saving on heating efficiency . I did install a 500 gallon Propane tank in anticipating a change over from oil.
I have a Knight boiler in my full time home for the last 11 years, No real problems to speak of except w/ add on computer control system. We have use a Few Lochinvar wall hung boilers and a few Navien units on other jobs. Only problems we have experienced was with a propane Lochinvar unit- main control board with 2 1/2 years of service.
With that being said I was hoping for some input as to install, service and reliability.
Thanks in advance for any input
navien is my choice right now then rinnia is my second and Utica would be my third.
the great thing about navien is they are 24 hour tech support , except holidays , I seem to fix most problems before I call, but I call to tell them what I done.
Rinnia told me that they have 24 hour tech also if you go threw the prompt0
- 128 Chimneys & Flues
