What Interfaces with an AirZone damper control system?
TimLS
I have a 16 y/o WaterFurnace geothermal system that is being replaced. There is a separate Water Furnace Zone Controller that interfaces with the AirZone system (Enerzone Systems Corp., 4103 Pecan Orchard, Parker, TX). I want to change my thermostat system to the Honeywell Prestige IAQ system that uses a zone controller HZ432K with 10 VA output. Does anyone know if this would be compatible with my AirZone damper system? I can't find any technical specs anywhere. If no info on AirZone, any other suggestions? I would like to avoid tearing up the basement to replace dampers.
Thank you
Tim
Thank you
Tim
- 133 Chimneys & Flues
