Williamson 5 in 1 anyone know the model number of the outdoor units
GW
Member Posts: 5,184
Any 1980's guys out there that know the model number on a Williamson 5 in 1?
My utility has a small kicker when we are downsizing. The name plate vanished years ago. Old system was a 30 amp and new system is a 20 amp, so my grand assumption is the we are smaller, hence the incentive through mass save
I don't but I wish I did. I just did a search on the 5 in 1 and there's very little information out there. I was looking for PDF files specifically but no luck.
This is the furnace I wanted when I started out but was living in an apartment at the time. I'm happy to say that I installed at least a couple of those.Steve Minnich0 -
I don't know but you jogged my memory, worked on one once with a line set that had a plastic suction line., those old pre charged line sets.0
good luck, they just completely fell off the planet, nothing, nowhere, what size supply duct? that could give you a cfm to run some numbers"The bitter taste of a poor install lasts far longer than the JOY of the lowest price"0
Outdoor unit would be 7420-xx-xxxx. The 2 digits in the middle tell the size. 25 is 2.5 ton, 03 is 3 ton for example.0
Thanks all, turns out the homeowner had the name plate filed away in the house. Who woulda thunk0
7320, that's a heat pump0
- 125 Chimneys & Flues
- 19 Recall Announcements
