What is in my water?
brandonf
Noticed this in my toilet tank. It's floating on the surface. I drink tap water so I hope that's not in it.
https://youtu.be/St4utIuCbY8
https://youtu.be/St4utIuCbY8 Homeowner, Entrepreneur, Mechanic, Electrician,
"The toes you step on today are connected to the butt you'll have to kiss tomorrow". ---Vincent "Buddy" Cianci
New toilet? If so could be oils on metal washers from shipping.0
About 6 years old.Homeowner, Entrepreneur, Mechanic, Electrician,
"The toes you step on today are connected to the butt you'll have to kiss tomorrow". ---Vincent "Buddy" Cianci0 -
Wish my toilet internals looked that good. Done any plumbing recently, change valves, etc...?0
What made you decide to look inside? Anything on the bottom side of the lid that may have dripped in? Looks like a petroleum based floater?
I suppose a lab could analyze it.
City water or a well?Bob "hot rod" Rohr
Living the hydronic dream0 -
Looks like tiny bit of oil to me. Maybe tiny spec of oil came off the rod where flush lever goes thru the tank ???0
Town well. Looked inside because I heard a trickle of water down the main stack and I wanted to see if the toilet was wasting water.Homeowner, Entrepreneur, Mechanic, Electrician,
I agree, looks like oil on top of the water. Maybe you should have the water analyzed.0
Sometimes when you remove lids, anything that was stored on top could drip in. Lotion, shampoo, whatever.Bob "hot rod" Rohr
Try running water from other taps into separate, clean buckets. Once they are still, see if any of that oily slick is visible. If it's only in the toilet, not so much of a problem.
Yours, Larry0 -
As Larry said, put water from tap into a separate bucket, and THEN, put one drop of Dawn dish detergent into the middle of the glass. If you see movement, there is most probably some sort of petrochemical in your water. Oil floats on top of water, and Dawn causes it to break up.
ME0 -
It is probably contaminated with di-hydrogen oxide.0
Are you in an area where there's oil fracking?0
1
It could be left over flux from when some work was done on the water system.
Toilet tank water does not see a total turnover after each flush and oils will stay on top....as we see in steam boiler installs.0 -
Sorry, no skimming port available on American standards or gerbers. Looks like you’ll have to use a glass cutting drill and make your own. Careful not to break the tank. At least you can pipe skimming to convient throneside drain.0
Built in skim port via overflow tube on WC tanks.
Unless you hold handle down until tank is emptied the top 2" of the water level hardly gets disturbed.
Getting the top level clean and seeing how long it takes to accumulate the same sheen would give you as idea of the concentration.0
- 135 Chimneys & Flues
- 16.2K Strictly Steam
- 52 Job Opportunities
