paint B.B.
Snowmelt
Snowmelt Member Posts: 1,457
I want to paint my B.B. covers to Bright white, I painted the rest of the room green with white trim, the B.B now is an almond color. what paint should I use? there is no rust.
GO.......................
  • STEVEusaPA
    It never looks right painted. Hopefully someone knows a solution.
  • Solid_Fuel_Man
    I've used automotive paint for CI rads. Local automotive parts store and they will mix up any color and put into a spray can. Been 5 years, and they have been exposed to 190 degree water a few times :#
  • HomerJSmith
    HomerJSmith Member Posts: 2,710
    edited March 2018
    I would use an appliance epoxy in a spray can that you can buy at Home Depot or Lowe's. Several lite coats are much better than one heavy coat. Don't worry about full coverage on the first coat. Clean the old paint on the baseboard with lacquer thinner and a rag to remove any grease before you spray the new paint.
  • ChrisJ
    ChrisJ Member Posts: 17,070
    They need to be absolutely spotless before you paint. If you decide to use the spray appliance epoxy as Homer recommended be warned it stays soft for a long time.
    hot_rod Member Posts: 26,594
    Check out the new SlantFin replacement cover system. Supposed to be available in colors. I saw a piece at the CMPX show this week, looks to be a top quality, heavy gauge system.
  • NY_Rob
    NY_Rob Member Posts: 1,370
    ^ Sweet!
    According to the video- the replacement covers are aluminum... no more rust!
