Trianco dbc-100 Boiler
FloydStoner
FloydStoner Member Posts: 1
edited March 2018 in Oil Heating
Any way to determine the manufacture date of this boiler? Plate on unit does not have a serial number. I'm guessing it's about 30 years old, but not certain. Attached Beckett burner was manufactured in December 1987. We're not original owners. Thank you.
    HVACNUT Member Posts: 7,526
    Trianco is now Laars. If you take the top off, there might be a stamping between the flue collector and the front of the jacket. In any case, it's a builders special steel boiler. Probably time to upgrade.
    kcoppSuperTech
  • rbeck
    rbeck Member Posts: 56
    These normally were sold as package units and I would assume the burner is original so boiler and burner are equal in age. I also believe that Trianco sold to Laars in the 90's but not sure about that time period.
