how much btu a pipe can give down
mottywalter
mottywalter Member Posts: 4
HI does anyone know of how much max btu a pipe size with give down by the liner foot ? for ex : i would like to make a heating coil for a pool with coper pipe !! i think we have to know first how much liner feet of a pipe will = a sq foot and then figure out of how much btu it can give down
    hot_rod Member Posts: 26,895
    heat exchange is usually calculated by square footage area of the material
    Temperature differential, flow rate, one or two pumped flows, etc. The math gets fairly complicated
    Take a look at factory built pool HX to get some sizing ideas
  • EYoder
    EYoder Member Posts: 60
    I doubt you'd want to use copper in contact with typical pool chemicals. Chlorine is corrosive, salt even worse.
    Most pool heat exchangers are stainless or titanium.
    I think chlorine can eventually damage pex...
    Maybe I'm not following what you're trying to do.
    EBEBRATT-Ed Member Posts: 19,791
    Take a pc of pipe or tubing 1 ft long and visualize splitting it down 1 side and unrolling it until it is flat. Then L X W would give you the surface area.
    Example: a pipe 2" diameter x 12" long would be: 2" x 3.14= 6.28"
    so 6.28" x 12"= 75.36 sq inches or 75.36/144=.5233 square feet per foot of pipe that has a 2" od
    it's just one pc of the puzzle. As @hot rod said there are many factors that go into it.
  • lchmb
    lchmb Member Posts: 2,997
    are you trying to heat a pool by a boiler or by solar? If solar I would use black water pipe...
    As longs the pool chemistry is keep in line cooper is fine. Laars and Raypak have been making copper tube pool heaters for a long time.
  • EYoder
    Hmm, I was wrong then.
    I've seen the copper brazing in a flat plate eaten out by pool chemicals. Tube and shell heat exchangers I've used are 316 SS or titanium heating the pool from a wood boiler.
    I agree, if the chemistry goes south I have seen solid bronze pool pumps destroyed by pool water.
  • EYoder
    edited March 2018
    I am curious what mottywalter has as a heat source. What the whole scenario is, water temps, etc.
