EcoSteam Inventory - PLCs and Parts
MarkS
Member Posts: 75
I have some remaining inventory from the EcoSteam project and wanted to give the folks here first pick before posting on eBay. Pricing for HH members will be lower than eBay.
PM me for more info, or email me at mark (at) thestaytons (dot) net
Here's what's in stock:
[6] fully assembled and tested PLC systems including TECO SG2 PLC, power supply, and terminal blocks in an Intermatic 2T2502GA NEMA 3R enclosure. These were originally EcoSteam units, but will NOT ship with EcoSteam branding or programming - that part's up to you. These would be good PLC trainers, or a platform for DIYers. The PLC supports ladder logic and function block programming. The programming software, manual, and application notes can be downloaded for free from FactoryMation. You'll need an SG2-ULINK programming cable to download programs to the PLC, also available from FactoryMation.
[7] TECO SG2-12HR-D PLC, 24 VDC, with 6 digital inputs, 2 analog inputs (0-10 VDC), and 4 relay outputs. DIN rail mounting. I also have a few 24 VDC DIN rail power supplies for with these units.
[10] Intermatic 2T2502GA plastic pool timer enclosures. These are great boxes for small electrical projects. 9 3/8" H x 5 1/2" W x 3 5/8" D. Combination 1/2 - 3/4 in. nominal knockouts, 1 on back and each side of enclosure and 2 on bottom.
[10] Building Automation Products, Inc (BAPI) Outdoor Air Temperature Sensor/Transmitter, in weathertight enclosure. Model BA/10K10-O-BB2, 10K-2 thermistor, transmitter range is -20 to 120 F, 15-24 VDC input, 0-10 VDC output.
[9] Building Automation Products, Inc (BAPI) Indoor Air Temperature Sensor/Transmitter combo. 10K thermistor, low profile button sensor (installs flush with wall, size of a quarter) with 10' plenum-rated cable. Transmitter range is 40 to 90 F, 15-24 VDC input, 0-10 VDC output.
[23] Thermodisc 36T22-11825 bimetal snap disc, normally open. Closes at 167 degF (75 degC), opens at 158 degF (70 degC).
Approx. [400] 2-level DIN rail terminal blocks in assorted colors. KONNECT KN-D12 series. 26-12 AWG, 20 A. [65] black, [110] blue, [75] green, [65] orange, [85] red.
[9] KONNECT KN-F10 DIN rail fuse blocks with end cover. 600 V, 6.3 A, AWG 26-8
[8] KONNECT KN-10J12 10-pole terminal block jumpers for KN-D12 series blocks.
[7] each red and green panel mount LEDs, 24 V, 1/2" dia.
1890 near-vapor one pipe steam system | Operating pressure: 0.25 oz | 607 sf EDR
Midco LNB-250 Modulating Gas Burner | EcoSteam ES-50 modulating controls | 70 to 300 MBH |
3009 sf | 3 floors | 14 radiators | Utica SFE boiler | 4 mains, 135 ft | Gorton & B&J Big Mouth vents
