Please Help With Baseboard Identification
Docfletcher
Member Posts: 490
Our baseboard is from around 1994 and some of it is pretty rusty. I'd like to replace some parts of it. So if you can ID it would be a big help thanks.
You can refinish them if you want. My local hardware store carries paint for those. Forget the brand name. Sand with a very fine sandpaper to get the shine off. Painted mine in place. Lots of taping off though. How do you keep your fins so clean?0
What I need to replace is way too rusty to paint. As far as the clean fins go I vacuum them ever so often. I've seen various replacement covers which mount over the baseboard online, all are very expensive.
Kcopp, I will check out Mestek. Thanks for the information everyone.0 -
To good to be true? Look what I found when I did Argo baseboard search.
http://www.parksupplyofamerica.com/gproduct.php?id=ARLLT2-8&fam=P71GYGE5A2YW&addons=y0
- 120 Geothermal
- 169 Indoor-Air Quality
