Is it Possible or Advised to "tweak" the Micro Switch on a M&M 150S-M-24 Feeder Pump Control
JUGHNE
Member Posts: 11,062
Would like a little higher water level in the boiler. Does anyone adjust the Switch setting?
I see that a lot of threads are available on the Allen set screw above the reed.
If the level isn't right you should raise or lower the control as needed...................But a small allen wrench (I think they put a drop of red Locktite on it)
I have adjusted them to increase the pump on--off differential or maybe I did it to increase the differential between the LWCO function and the pump control.
Can't remember exactly but YES. As long as the controls keep the water level safe I see no harm. You can always set it back where it was and put the locktite back on!! Even though I am sure it's a no-no0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
