Lochinvar Noble Troubles
heidleml
Member Posts: 36
I have installed quite a few Noble combi unis this year. On the last two installs however, the boiler circulator was stuck. Called tech support and they told me to take circulator out and free up the rotor. The guy knew right away what the problem was. Just wondering if anyone else is having this problem...
Also, if this happens again I may try and get some warranty labor out of Lochinvar.
Shoot is that good or bad he knew what it was. Don’t bite the hand too hard0
I have put in quite a few. Yes had some stick. Only had to remove the pump on one unit, it was installed backwards (not facing the front). I couldn't get to the vent screw. They do use a grunfos pump and usually make sure to purge the air out and that seems to do the trick. But too learned the hard way first, air seems to be a issue getting out of the boilers, I think they should also use a air vent on top like the others do.
A lot of purging does seem to get the job done.0 -
I sold a Knoble to a heating contractor he installed the combi boiler started it and he had steam coming out the air vent. He told me the pump inside the boiler the wire was not connected.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 945 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
