Water Test for Boiler-
ced48
ced48 Member Posts: 469
edited February 2018 in THE MAIN WALL
So, when testing water for a hydronic system, I need to test for Ph, hardness, and TDS?
  • flat_twin
    flat_twin Member Posts: 355
    and chlorides.
  • ced48
    I just got the water some quality numbers from are town water department. To me, they look real good. Chloride 23ppm, pH 8, Chlorine .68 ppm, TDS 56-74, hardness 35.7 ppm-
    hot_rod Member Posts: 26,597
    Does the town have just one water source? Is the test current?
    Test results can vary throughout the year and if they switch or blend sources
    It’s best to test at your home also. Those are good numbers when compared to most of the boiler installation manual fluid specs
  • ced48
    Yes, there are 6 wells, but all are treated in 1 location. Test is a few years old. Just thought this was an easy way to get an idea of wether or not I might have a problem.
