Small oil furnace
Jon_blaney
Jon_blaney Member Posts: 335
Can you get a 40,000 btu hot air furnace? I need a plan to replace my current unit which is now to big due to weather sealing and insulation.
  • STEVEusaPA
    Oil? Not in America.
    HVACNUT Member Posts: 7,451
    You'd have to research but some furnace manufacturers offer a 2 stage Carlin burner that you might only ever need low fire.
    Also look into a good steam humidifier.
  • Jon_blaney
    I can not find anything even the 2 stage burners are to large.
  • lchmb
    lchmb Member Posts: 2,997
    gas..low fire may get you what you need...and or a boiler with an air handler...
    Try calling Carlin Combustion. I can't seem to find my info on the 2 stage EZ and can't remember which furnaces it is offered in.
  • Robert O'Brien
    Robert O'Brien Member Posts: 3,591
    Boyertown furnace
    > @Robert O'Brien said:
    > Boyertown furnace
    Nice. Have you ever installed or serviced one? I haven't had the pleasure.
  • Jon_blaney
    Thanks, this is what I need.
