Honeywell Zone Valve o-ring size?
nj6964
nj6964 Member Posts: 22
I had an o ring leaking on a 3/4 Honeywell zone valve. I had an old one that I borrowed the o ring from for now. However, I can’t find the exact size of this o ring anywhere online. I see a ball and o ring kit for $30 which seems crazy when all I need is the o ring. Anyone know the size or have a good source? Thanks!!
    hot_rod Member Posts: 26,594
    Most automotive supply places have O ring assortments. Usually they can match up a ring for you.
    Hydraulic repair shops have a much larger assortment of standard and metric sizes. Some shops have O-ring kits that you cut the length and super glue the size you need.
    If 30 bucks includes shipping it may be less $$ then chasing one down?
    Grallert
  • JUGHNE
    JUGHNE Member Posts: 11,513
    HW O-ring for V9043.......272756A
    Bag of 5 I brought in 2007, maybe $3.00 each or the bag....not sure. Got thru a wholesaler in Omaha NE.
