Warren Webster Traps Seat Nut Size?
Harry_6
Member Posts: 147
A quick question: Does anyone know the size socket required to remove the seat from a W-W 512, 522, 533, etc.? Unfortunately, I don't have the tool W-W made for this, and I don't had access to a trap I can check, but wanted to have the right socket before going to the job. And by the way, I do have the wrench they made to remove the cap, so if anyone has a spare of the little socket gadget they made to fit in the wrench's square hole to remove seats, I'd be pleased to purchase it from you! -H
I don't know 100% but I think it's 3/4" or very close to that size. Most trap seats are 3/4" hexPeter Owens
SteamIQ0 -
@Harry: I pulled a WW 512 HB from our "petting zoo" of steam parts and I am getting a measurement of the seat (in our example) at 1" even.
Often, there ain't much clearance between the seat flats and the bottom of that trap, so a special thin-walled socket might be needed. Usually, its pretty crusty down there, too. Full of vitamins! Sometimes, I've even ground the bevel off the bottom of the socket to enable a better grip on the relatively thin seat.
These deep traps are an overall challenge to deal with.
You may consider a full replacement of the trap, especially if it is a cross-over trap and you have to work overhead by braille.
https://heatinghelp.com/find-a-contractor/detail/all-steamed-up-inc0 -
Thanks. Yes, I assumed it might take some grinding of a socket, since I had that same experience of it being pretty tight (and cruddy) for a normal one. That's why I was wishing I had the W-W socket that goes with the cap wrench. Oh, well. . .0
- 86.9K THE MAIN WALL
- 57 Biomass
- 109 Chimneys & Flues
- 5.7K Gas Heating
- 105 Geothermal
- 70 Pipe Deterioration
- 973 Plumbing
- 6.3K Radiant Heating
- 386 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
