Weil McLain gold series one water temperature
jaykilty
Member Posts: 1
in Gas Heating
My plumber and I am a electrician, have been throwing parts at this system without success. The boiler is in my home. Problem is boiler temperature. Will not reach even 160* the high limit which is new is set at 180* and was the first part the rep from Weil McLain said to replace. Next was the return water temp sensor. This morning we replaced the control. (1030-200). Same problem. We are at a loss. Weil McLain tech service is not very good. Any ideas? System circulators work. The burner just shuts down before reaching 180* and will not re-fire till around 120*. We also jumped out the limit that is on top of the boiler under the circulator and the results were the same.
How are you taking temp readings? The tridictator could be off.
What type of emitters?0
- 125 Chimneys & Flues
- 19 Recall Announcements
