Cast iron baseboard output
WJurgens
Member Posts: 7
We have about 70' of this cast iron base board show in the picture. It is located in a house and we are trying to properly size a steam boiler to handle the load
I'm told that the cast iron element measures about 4" deep and is 6" wide. is has a sheet metal enclosure around it to enhance convection.
does anyone know a square foot EDR rating on this per lineal foot? Any idea who the manufacturer was on this?
thanks!
Warren Jurgens
JM O'Connor
Lenexa KS
thanks!
Warren Jurgens
JM O'Connor
Lenexa KS
That is a convector and it sure needs cleaning to get any output.
Look fo a manufacturer or name on it. If you can't find one measure them up and find a manufacturer that make one a similar size and use that rating. It will be close enough. Their is probably some information available on his site0
- 119 Geothermal
- 394 Solar
