unbalanced requirements between forced air and radiant heating systems in canada
Nron_13
Member Posts: 164
Hello Guys please take a look at the attached link and see if you think that the requirements are unbalanced between hot water based systems and the standard forced air
http://www.municipalaffairs.gov.ab.ca/documents/14-BCI-010-JointHydronicHeatingSystems.pdf
Nron in alberta canada
That is certainly a well thought out bulletin. Is there a similar one for FA HVAC to compare to?
It is good to see the various hydronic groups come together to develop that guideline.
I know Paul got an earful from contractors at a recent hydronic gathering as far as what is realistic and what is wishful thinking regarding codes and enforcement.
ME was on that panel also. Nice to see the govt and contractors get together in a room to hash out these concerns.Bob "hot rod" Rohr
Living the hydronic dream1
