Hydronic Radiant Heat Retrofit on uninsulated concrete slab basement
Check out Legend Versatherm panels. It's more like a floating floor. We use them in basement applications or kitchen remods where the customer wants to get rid of cast iron rads. I've used them with both modcon or electric boilers.
Owner of Grunaire Climate Solutions. Check us out under the locate a contractor section. Located in Detroit area.
- 129 Chimneys & Flues
- 122 Geothermal
