When installing condensing boilers / condensing combi boilers are you using the following?
bob eck
Member Posts: 930
Are you installing P/S piping kits like Webstone if available or needed for the brand boiler that you use?
Are you installing dirt magnet separators?
Are you venting with PVC, CPVC or Polypropylene?
Are you installing Hydraulic Separator like the Caleffi 4 in 1 with dirt magnetic?
Are you flushing the system with cleaner and then adding treatment chemicals after installation?
I generally try and use brand specific piping kits with the boiler if available. Otherwise I always prefer to pipe p/s. I've never had luck piping in and out. I only use seperators on cast iron baseboard. I do install them if the manual specify it be installed. In NH you cannot vent a boiler with PVC. I try for Poly to make life easy..We flush every system, but I generally dont use a treatment...It's not something that is thought of very often by our salesman...0
No.
Sometimes.
CPVC
Yes.
Yes.Steve Minnich0
- 87.1K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 5.7K Gas Heating
- 110 Geothermal
- 161 Indoor-Air Quality
- 70 Pipe Deterioration
- 996 Plumbing
- 6.3K Radiant Heating
- 391 Solar
- 15.4K Strictly Steam
- 55 Water Quality
- 44 Industry Classes
- 48 Job Opportunities
